Trade: appliance sales and installation
Air Bubbles Under Laminate Flooring
Any suggestions for getting large air bubbles to release? The laminate floors have a few places where the edge gap wasn't large enough and the flooring is touching the wall. Seems like the flooring expanded with the damp winter weather and maybe it isn't air, it is buckling up. There is also a place where it butts up to fireplace tile, and that was caulked to cover the gap, though it isn't much of a gap. Pretty tight around it.
Dave from Macatawa
Trade: GC, cabinet maker and remodeler
Re: Air Bubbles Under Laminate Flooring
Burp it like Tupperware.
Trade: framing/remodeling
Re: Air Bubbles Under Laminate Flooring |
It won't burp, air goes out and goes back in.
Trade: flooring
make the correct gap all the way around. Or Momma will cry when you have to rip it all out.
olzo |
Trade: Flooring
Its not air-
The floor has expanded as all alminates do, and if there was not enough expansion space left around the parimeter then this will happen. Only recourse is to remove all the base and cut the laminate back- You have to get a saw designed for that though. |
#7 | |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Re: Air Bubbles Under Laminate FlooringQuote:
There are no shortcuts. Do it right or not at all.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
Flooring Guru
Trade: Sales Manager
I agree
------------------------ "in 20 years you will regret more what you did not do than what you did" |
Flooring Installer
Trade: flooring
All you can do is trim it. Remember, not only does the floor expand and contract, so do your walls.
Trade: -
I would suggest having heat over the lamination. While adhering the lamination if we use medium hot surface to roll the lamination, then the bubbles might get out rapidly. I dont have much experience with large sheets, but with smaller ones it works perfectly.
Knowledge Factory
I think you may be from another country, other than the US, maurisgreen.
We are talking about laminate plank flooring. Nothing glued down to heat and restick.
Great advice. Thank you.
Floors San Francisco
Trade: Flooring
TAke off the baseboards or quater round and make the expansion gap and wait.
What can I tell you? It is not easy to make the expansion now , very precise cut needs to be made there is a toe kick saw that would get it nicely but you have to to it precise. If you think there is a lot of exposure to moisture you might think of a big gap say one inch. You can install baseboard and then quater round to it. This is the only solution make the gap and wait then when the floor settles down install the baseboards. hardwood floor hawaii hardwood floors san francisco hardwood flooring hawaii Last edited by hawaii; 07-04-2011 at 02:34 PM. |
Trade: hardwood flooring
If the walls are drywall you can also get your expansion cutting the drywall.Little easier than trimming the wood.Good luck
| Tags |
laminate floor ![]() |
| Laminate flooring lifting up. | combuilder | Flooring | 5 | 02-18-2009 08:14 AM |
| Laminate flooring issue with customer | beachwork | Flooring | 23 | 10-29-2008 09:35 PM |
| What to charge to pull up 325sqf of Laminate flooring?? | TileMan77 | Flooring | 3 | 07-17-2008 08:57 PM |
| Air Bubbles in Laminate Flooring | Bigman | Flooring | 19 | 09-05-2007 10:07 PM |
