Acceptible Tolerance On Subfloor?
Old 06-06-2007, 09:02 AM   #1
Danno6102's Avatar
Trade: Deck Builder
I just laid some sub floor in my remodel & forgot to check the level of the joists before I did it. One of them was slightly higher. When I lay my 6' level across the high spot I get about 1/8"+/- gap at the end of the level, so 3' from the crown. Will this be noticable once I get the finished flooring down? It's going to be hardwood, either laminate or planed siding from the 107 year old barn on the property, which I have another question about for another post.
Thanks,
Dan
Danno6102 is offline
Old 06-06-2007, 06:14 PM   #2
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Re: Acceptible Tolerance On Subfloor?
Pop that sheet back up and plane the joist down, problem solved. Btw hardwood specs are generally 1/8" in 8ft.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Oak flooring over cement subfloor Nick H Flooring 33 04-16-2009 03:48 PM
Concrete backer over 1/2 inch subfloor jim20 Ceramic & Stone Tile 4 08-01-2007 11:22 PM
subfloor lowell5slide Flooring 4 06-04-2007 01:41 PM
subfloor recommendation for ceramic 72chevy4x4 Flooring 5 10-03-2006 09:34 PM
fixing subfloor bigjohnsons34 Flooring 14 09-08-2006 06:01 PM
