Trade: Floorcovering
3/4" White Oak Hardwood Over Radiant Heat
Flooring contractor here in the Midwest, I have just bid a job to install 2 1/4" White Oak Common over a radiant heated floor. The "tubes" are located in the center cavity between the joists. My "plan" was to glue down the tar paper with a multi purpose adhesive, full spread, then use construction adhesive and nails at the joists to install the hardwood.
Anybody have any tips or other suggestions on this procedure? Its approximately a 1500 square foot job.... Thanks in advance! |
Army Ranger
Trade: flooring
Re: 3/4" White Oak Hardwood Over Radiant Heat
Gluing tar paper that is saturated with petroleom products with latex adhesive is not a good idea. There is no reason to glue the felt paper to the floor anyway. Just install the paper with staples as usuall and nail the flooring with 1.5 inch nail or staples wichever method you prefer. That is how we install hardwood over 3/4 plywood that has been nailed or glued top concrete slabs and you dont get any penatration of the subfloor. You need to nail the floor on aleast 8" center because with the radiant heat you are really stressing the floor during the heating season Hope this helps.
floorinstallation@cox.net |
#3 | |
Re: 3/4" White Oak Hardwood Over Radiant HeatQuote:
Thanks Again in advance! |
Army Ranger
Trade: flooring
The shorter nails will definatly work. It meets NOFMA standards and since the holding ability of the fastener is greater when you don't have penatratiion of the sub floor. This is because the holding ability of the fastener is directly proportional to the coefficient of friction on the fastener. This coefficient is greater when you don't have penetration due to the fact that the compression of the substrate around the fastener is higher. By penetrating the substrate you relieve some of the pressure around the fastener. I would stay away from 1 1/4" nails because a reduction of 1/4" results in a lose of approximatly 20% of the length of the fastener with a coresponding reduction in the amount of friction area acted upon by the compression of the substrate. Also never try to nail to a particale board because it has no ability to compress around the fastener. I would not recommend glue the floor in adition to nailing. It is not necessary and will inhibate the ability of the floor to expand with the change in moisture content which will be greater than ususall with radiant heat. Any restriction of the floors ability to move could cause buckeling or panelizing of the floor. Just be sure that when you nail the floor in place that you use a minimum of nails 8" o/c or less.
floorinstallation@cox.net Last edited by floor instal; 04-14-2007 at 12:09 PM. Reason: added info |
Thanks Bud for the time you have taken! We will go with the 1 1/2" staple and no glue....
| Electric Radiant Floor Heat | kpikul | Flooring | 15 | 01-27-2012 04:03 PM |
| Demo a foundation under a radiant heat slab without disturbing the slab...? | wackman | Remodeling | 18 | 04-02-2007 12:38 AM |
| Hardwood Over Radiant Heat | Dave Buskirk | Flooring | 5 | 01-03-2007 09:11 PM |
| Hardwood Floors over Radiant Heat | bigtick | Flooring | 10 | 12-08-2005 03:43 PM |
| Heat Exchanger Inspection Methods | MechAcc | HVAC | 3 | 04-14-2005 04:38 PM |
