Trade: Builder
3/4 Oak - Meets - Tile Rooms With Tile
A home I'm CGing has 5/8 plywood as the subfloor above the joists. Has some weak dips in areas when you wall over so from underneath I have supported these areas with a 3/4 piece of Advantec nailed up underneath with 2x4's.
All of the flloors will be 3/4 oak and my concern is the bathrooms. To line up the bathroom tile with the 3/4 wood flloors, how would you do it. I was thinking 3/8 plywood glued and screwed, a 1/8 for Schulster Ditra and the remaining 1/4 for tile and grout. Does this sound right? Thanks everyone |
It is what it is
Trade: Roofing, Remodeling, Concrete
Re: 3/4 Oak - Meets - Tile Rooms With Tile
I always use hardy backer and on floors i use 1/4". The 1/4" hardy backer and tile are almost a perfect match for 3/4 hardwood.
Patriot Broadcasting Network |
Trade: siding windows soffit fascia
I'd use the 3/8" ply and Ditra for my .02 worth. I really like the Ditra and I think it's superior to backerboard CBU whatever.
Especially in a bathroom where not many sq feet, easy to use, not much $$. Dave C
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors |
tile contractor
The only problem with the plywood and Ditra is that it only leaves you bout 1/4" for the tile, and that ain't gonna cut it, unless you're using ceramic mosaics.
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com |
| quarry tile to quarry tile | rservices | Flooring | 8 | 01-15-2010 12:37 AM |
| Learning to install Floor and Wall Tile!! | TurnkeyConst | Flooring | 25 | 01-17-2008 08:01 PM |
| odd bullnose tile | mdshunk | Ceramic & Stone Tile | 25 | 09-18-2006 11:25 PM |
| Got some design ideas for tile wainscoting? | Mike Finley | Ceramic & Stone Tile | 2 | 05-09-2006 10:05 AM |
| Cutting Existing Tile. | kpikul | Remodeling | 16 | 02-05-2006 12:30 AM |
