3/4 Hardwood Laid Parallel To Joist?
Old 10-06-2006, 02:05 PM   #1
pburchett's Avatar
Trade: General
New construction has a 34’ wide x 28’ long family room attached to a 4’x 28’ hall.
The 1” x 8” sub-floor runs the length of the room and hall.
Want to install Ύ” red oak flooring:
1. If installed the 56 foot length of the hall and family room the flooring would be perpendicular to the joist, but parallel to the sub-floor. Would this make for an un-level floor, with the hardwood riding on the edges of the 1”x 8”? What if I went over all of it with a floor sander first?
2. If installed perpendicular to the sub-floor and parallel to the joist, would there be any sag between the joist? Would the tongue and groove on the flooring provide enough strength and support when combined with the sub-floor?
We do not want to add any additional panels (osb or plywood) on the floor as the hardwood would now be flush with the tile and carpet if installed directly on the 1”x 8” sub-floor.
What to do???
pburchett is offline
Old 10-06-2006, 03:01 PM   #2
Project53's Avatar
Trade: Project Manager
Re: 3/4 Hardwood Laid Parallel To Joist?
?????? What????...your dimentions make no sence..a 1"x8"...what is that?..are you saying thats a joist? or sub floor dimention some how......and you want to do what..sand the sub flooring?????
Project53 is offline
Old 10-06-2006, 03:36 PM   #3
Tom R's Avatar
I'm takin' it he means 1 X 8 planks.
Perpendicular to the planks is usually the best bet, - - unless they're dipping now.
Trouble is, - - the job would look a lot better going parallel.
Personally, - - I'd either add 1/2" of plywood first (that's not a big transition) and go parallel, - - or go diagonal and direct . . .
Tom R is offline
Old 10-06-2006, 03:38 PM   #4
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
The new hardwood needs to be laid perpendicular to your 1x8" subfloor. This will minimize movement and add stability and flatness to the new floor. If the subfloor was osb or plywood then you lay perpendicular to the joist. Even if you sand the 1x8 subfloor flat it could still cup with humidity changes thus making the new floor look like crap.
Ya beat me too it TomR.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 10-06-2006, 03:43 PM   #5
Tom R's Avatar
Whew!! Finally.
Tom R is offline
Old 10-06-2006, 03:59 PM   #6
Peladu's Avatar
This is clearly a HO ... read some of his last/only posts and he is building a home for his family...
Too bad he seems to be so far into his project...I could have offered him my SC2C discounts.
Peladu is offline
Old 10-06-2006, 07:29 PM   #7
Project53's Avatar
Yeah, Peladu....nothing makes sence so i think...it should go to the DIY section.
Old 10-07-2006, 12:10 PM   #8
Peladu's Avatar
pburchett must have some clout around here .... otherwise this thread would have been locked
and given the standard "Go To DIY Chat" response.
Peladu is offline
Old 10-08-2006, 07:10 AM   #9
pburchett's Avatar
Trade: General
Thanks Tom R and Big Dave.
Old 10-08-2006, 11:37 AM   #10
Moderator
Double-A's Avatar
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
New York Times, July 20, 2006
Double-A is offline
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
Floor Joist dante1 Flooring 0 02-14-2007 06:02 PM
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 09:07 AM
Questionss on Hardwood underlayment and expansion newtofloor Flooring 8 11-24-2005 08:18 PM
