3/4 Hardwood To Carpet Transition
Old 03-16-2011, 11:09 PM   #1
discombobulated's Avatar
I'm using the "tack and tuck" method. I've done hardwood a few times before but have never worked with carpet. I'm not sure if it's because of the older carpet/pad or because I'm doing something wrong. I have my header board in place, left 1/4 inch overlap on carpet beyond the header board. Tack strip is 1/4 inch away from header board, then padding 1/4 inch away from that. I'm trying to tuck but when I go to pulling and tacking the carpet down, it won't stay once I try to tuck the carpet. Do I have to somehow hammer the tack strip nails down to hold the carpet in position? It's not as graceful or as graceful looking as the pics I've seen on hardwoodinstaller.com page. If all else fails, I've made a failsafe to put traditional transition molding there. Any advice, please?
Also, this is for a family member who said he's replacing the carpet soon so it's not something I'd try with a paying customer.
discombobulated is offline
Old 03-16-2011, 11:25 PM   #2
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Re: 3/4 Hardwood To Carpet Transition
Do u have access to some form of stretcher ,knee kicker? U have to have some form of linear pressure"negative resistance in order for the tack strip to do its job......first have your carpet overlapping ur wood....second get a kicker and kickthe carpet with the head of the kicker ending on the tackstrip....third do a flush cut along the hardwood with brand new blade.....then resnug and tuck the carpet four inches wide at a time about the width of yer kicker head should work fer ya ! Thumbsup
Groutface is offline
Old 03-16-2011, 11:41 PM   #3
Ok, now I feel stupid but I checked out another link. Apparently they're tucking the carpet into the groove of the flooring strip, right? The previous pic I've seen made it look so flush with the top of the carpet that I thought they were just folding 1/8 or so of carpet down and against a ripped strip. Days like this make me really think why I don't do simple factory assembly work.
And no, I don't have a carpet stretcher and he's not concerned with renting one since he's replacing it soon anyway.
Old 03-16-2011, 11:44 PM   #4
Groutface
Groutface's Avatar
Rewards Points: 524
Good to go then! Thumbsup!
Old 03-17-2011, 12:29 AM   #5
Ok, so the strips I have in now have no grooves. It's either tear them out or route some in while they're in place . I have no router, suggestions? I'm only a lowly laborer so I haven't developed much of an arsenal of tools yet.
Old 03-17-2011, 12:40 AM   #6
Floor Doc's Avatar
Trade: Flooring , Flooring Inspections
Rewards Points: 25
cut them out with a dremel .
Floor Doc is offline
Old 03-17-2011, 01:14 AM   #7
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,266
skill saw?
Metro M & L is offline
Old 03-17-2011, 01:44 AM   #8
I'll give the Dremel a shot though I expect to just tear it out and start a new header board. Dremel and straight lines don't mix, at least not with me. Thanks guys.
Old 03-17-2011, 09:27 AM   #9
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Ugh. Why does so much misinformation get thrown around like truth here sometimes. Seriously - if you don't know, don't answer, its that simple. These threads are usually helping someone complete a job for a paying customer.
No groove is necessary. A stretch on the carpet to engage the pins on the tackstrip is however. This can be accomplished with a power stretcher or a knee kicker. The tackstrip should be installed with the pins angled toward the carpet side of the doorway so they hook the backing when stretched. Leave the strip 1/4" away from the wood and tuck the carpet edge into the gully.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
The Following User Says Thank You to PrecisionFloors For This Useful Post:
opiethetileman (03-18-2011)
Old 03-17-2011, 09:41 AM   #10
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,062
Why don't you run up here & teach me how to do it? Everytime I have to find someone to do it for me, I swear, I'm gonna learn. Been sayin that for a couple years now.
Oh, did I mention, I hate carpet & have very little desire to learn much about carpet.
pinwheel is offline
Old 03-17-2011, 10:21 AM   #11
Floor Doc's Avatar
Rewards Points: 25
Ya don't leave the tongue on facing the cpt .
Old 03-17-2011, 02:35 PM   #12
Groutface
Groutface's Avatar
Rewards Points: 524
Nice!
Old 03-17-2011, 03:11 PM   #13
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 48
Actually, the pins should point away from the carpet side of the doorway, so the carpet will hook on it and not pull off when you relax the stretch.
Flooring installer since 1973
Armstrong certified
rusty baker is offline
Old 03-17-2011, 03:40 PM   #14
Paul
You're correct Rusty. I was so wound up over the misinformation I missed that....I type faster than I can think sometimes lol.
Precision Floors
(772) 237-9900
Old 03-17-2011, 03:53 PM   #15
Groutface
Groutface's Avatar
Rewards Points: 524
I missed that also... and getting wound up means u care about what u do....thumbsup
Old 03-17-2011, 06:17 PM   #16
Groutface
Groutface's Avatar
Rewards Points: 524
Go up to my earlier post and follow too a tee....or what precision saidf
Old 03-17-2011, 06:50 PM   #17
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Here's one way...
1) Undo the cut that you've done in the carpet.
2) leave about 2 inches straight into the doorway/transition.
3) Roll the flap underneath..making a nice crease tight to the wood.
4) separate the pile, and shoot 1/4" crown staples tightly..as needed
5) fluff and run
Or buy a crimp down extrusion..
I don't like tack strips across traffic areas...
-Steve
TimelessQuality is offline
Old 03-17-2011, 07:02 PM   #18
Flooring Installer
Trade: flooring
Rewards Points: 48
Originally Posted by TimelessQuality View Post
Here's one way...
5) fluff and run
You are right. According to CRI, you are to never put tack strip across a doorway, but it's done all the time. You should use a transition strip, but they are ugly.
Armstrong certified
Old 03-17-2011, 08:07 PM   #19
Floor Doc's Avatar
Rewards Points: 25
I took his first post to mean he wanted to remove the tongue .
Old 03-17-2011, 11:26 PM   #20
PrecisionFloors, thanks, you're right. I think I got it down pat after finishing the doorways. It also saves the customer on transition pieces while not having a tacky raised piece in the doorway. As a first timer, it's a bit scary making sure not to cut too much off.
Also, this friend of a friend before doing the transition pieces, he accidentally covered a vent hole. I, I mean, he has a stud finder and had no luck finding the hole since the flooring's so thick. Is there a good way you guys use to locate those? It's by the patio door which is coming out soon and would be no problem to take a piece out close to it when it's out to find it but would rather do it sooner to get that out of the way. Thanks.
Carpet Laying Tips Bozzy Flooring 122 11-16-2015 06:59 PM
Curved transition from hardwood to tile wannaBelkhuntin Tiling 9 07-09-2012 09:49 PM
To all you Carpet owners.. Check this out AcademyHardwood Carpentry 7 10-13-2009 10:33 PM
Price to install real hardwood flooring and remove carpet Handyman4u Flooring 15 02-21-2009 09:36 PM
How to edge Carpet at radius abutting Hardwood caswensk Flooring 2 10-12-2008 11:14 PM
