Trade: Remodeling, Home Improvement, Decks, Etc.
1st Laminate Job Need Help
I am installing Kronotex Laminate from lowes in a hallway.
I know that all the jams have to be undercut but, I have a ton of angles and there are 4 door wyas in this hall how do I cut this stuff without chipping, and how do I make alll the needed cuts without roughing the edges? I took all the cove base out and will install new base molding when finished ... i could not bring myself to use the 1/4 round... Thanks for any advise and or help that is offered |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Re: 1st Laminate Job Need Help
Table saw with a 36 or higher tooth count circular saw blade blade in it. You will also need a jigsaw with a good fine blade as well.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
Thanks,,,
another question when having to work in an L shaped hallway with 6 door openings, and trying to maintain the grain direction ho does one turn the corner, without ripping the one pice of laminate down >> |
#4 | |
Remodeler
Re: 1st Laminate Job Need HelpQuote:
When wrapping doorways without a transition, it is imperative to think a few rows ahead to insure an end joint can and will fall in the easiest place possible to make your way thru the door....at or near the middle in most cases. You can also drop a tape and figure out what the starting row must be ripped down to so as to not leave yourself straddling and wrapping a door casing casing. If you set it up so that your wrapping point has a long join in the middle and an end joint at or near the middle the other way it becomes easy as pie...with casings undercut and base removed I can typically make those cuts with only a table saw and very often they are measured and marked without the aid of a tape measure.
I'm having a hard time following this. Are you putting it down on a 45* angle? If not, what direction are you running it? Is it going to continue into the rooms?
As for chipping, I always cut it from the back side plus it's easier to mark. Buy new carbide blades and change them when they start to get dull. When using a table saw, cut finished side up. You always want the teeth going INTO the finished side.
The hallway is about 8 feet long and then it turns left to access three bedrooms ...
I will post pics if possible today.... I am runnig the grain length ways with the walls and yes I am splitting the door ways at the bedroom where it will transition to carpet there |
| Getting laminate under door casing and jambs | Blackhawk | Flooring | 6 | 01-02-2008 04:14 PM |
| stainless steel laminate | Mr. D | Kitchens & Baths | 3 | 08-07-2007 02:02 AM |
| Miter Joints In Laminate Flooring ?? | AL MURZYN | Flooring | 6 | 12-27-2006 10:15 PM |
| Laminate Floor | Richard | Flooring | 15 | 12-22-2006 12:59 PM |
| Tile or Laminate | jwaldman97 | Flooring | 15 | 10-14-2006 06:41 AM |
