1958 Floor Tiles ,vinyl ?? Squares Asbestos????
Old 01-27-2008, 09:45 AM   #1
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
What precautions should i take to remove? No I'm not going for a $$$$$
abatement co. New tile going in .thanks
Driftwood is offline
Old 01-27-2008, 09:53 AM   #2
Rewards Points: 2,000
Re: 1958 Floor Tiles ,vinyl ?? Squares Asbestos????
90% certainty...vinyl/asbestos.
Your house or a customer?
neolitic is offline
Old 01-27-2008, 09:59 AM   #3
mickeyco's Avatar
Trade: Squirrel Handler
If you hire illegal aliens to remove them no precautions are necessary. The building next to mine (same building, same asbestos tile) is being renovated and they have a bunch of illegals just tearing them out and tossing them in a dumpster.
mickeyco is offline
Old 01-27-2008, 11:59 AM   #4
Al Smith
A W Smith's Avatar
Rewards Points: 1,000
I can almost guarantee they are 9 X 9 asphalt/asbestos tile.
asphalt asbestos are black.
vinyl asbestos are green or red.
three important things about asbestos you should remind yourself about.
1) there is no safe limit for exposure to asbestos fibers, You can get mesothelioma from a single fiber
2) there is no cure for mesothelioma.
3) mesothelioma is always fatal, death usually occurs within five years of diagnosis.
this does not mean you will get mesothelioma from exposure. There are many who live full productive lives breathing this stuff with no complications whatsoever perhaps with just a bit of lung scarring. But if you are diagnosed thirty of forty years later, get your estate in order because you are done.
If you want to do the removal here are the guidelines
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-27-2008, 02:33 PM   #5
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Thank you all! I will follow all the guidelines. I'm a g. c. that doesn't sub out much. I have a graingers acc. will do it right. Illigals need their lungs also!
Old 01-27-2008, 02:34 PM   #6
Gee Al,
What a cheery little note
for a sunny Sunday!
Signed,
A former installer of commercial transite siding.
(But it only been 35 yrs ago)
neolitic is offline
Old 01-27-2008, 02:54 PM   #7
Tom R's Avatar
Rewards Points: 2,036
Best thing to do is leave it down and just go over it, - - if that's an option . . .
Tom R is offline
Old 01-27-2008, 03:52 PM   #8
Al Smith
A W Smith's Avatar
Gee Al,
for a sunny Sunday!
Signed,
Ive installed transite myself. And Ive removed it. And Ive used a masons hoe to reach in and pull the debris out of my pickup utility cap in a cloud of dust and into a four yard dumpster 25 years ago. So yes i have been exposed to it too. Many times. Yes i have some lung scarring. Yes i could very well die from it. I almost expect to. I used to think the warnings were of an exaggerated environmentalist alarmist nature. Then I did some research. And the results are unsettling to say the least.
Al Smith
Old 01-27-2008, 04:01 PM   #9
Nobody even told us there was asbestos
in that stuff.
We wore bandannas for face masks cause
the dust from the worm drives caked in your
nose and throat so badly.
AAAH, the good ol' days!
neolitic is offline
Old 01-27-2008, 04:10 PM   #10
Al Smith
A W Smith's Avatar
correction i never installed Transite. Thats the indestructible asbestos cement sewer pipe from the sixties and early seventies. i installed supradur asbestos cement siding.
Al Smith
Old 01-27-2008, 04:21 PM   #11
Transite siding too
http://www.washingtonpost.com/wp-dyn...2004Dec17.html
Generic term, like Coke or Kleenex.
Stuff we put on schools and hospitals
was 2" siding and 1" soffit.
neolitic is offline
Need some help on Removing Asbestos Siding TurnkeyConst Construction 7 12-02-2007 06:55 AM
Asbestos And Linoleum Angus Flooring 4 11-06-2007 10:58 PM
Removing asbestos floor tile: Space suits needed? Ted W General Discussion 19 01-29-2007 01:38 PM
Asbestos siding osborn Painting & Finish Work 5 01-05-2007 06:20 AM
