10k Square Foot Gym - Flooring - Contractor Talk
10k Square Foot Gym
Old 01-10-2012, 05:39 PM   #1
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,356
10k Square Foot Gym
Got an rfp on a gym. I haven't done a space this big before. What should I be aware of?
Talked to one of my suppliers who suggested a sub who has the riding sander equipment and some masking machines to do the lining properly.
My main question is where do you get 220 in typical sports facility; mechanical room?
Metro M & L is offline
Old 01-10-2012, 06:14 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 3,236
Re: 10k Square Foot Gym
Was a cushion floor spec'd out?
Did you do a moisture test on the slab?
220v should be and is usually readily available inside the gym or if need be from a mech room. If not in the gym how far away is it & who will supply wire & install it?
If you haven't done a job that size before I'd reccommend getting someone who has to work with you.
Sub the lines out. Unbelievable how fast a guy can do it.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
CO762 (01-10-2012), Metro M & L (01-10-2012)
Old 01-10-2012, 07:31 PM   #3
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Generator. People may be able to get lucky and hook into 220, but the distances can be great and/or become greater. If you're going to rent a machine, rent a generator also and maybe get a better deal for all.
CO762 is offline
The Following User Says Thank You to CO762 For This Useful Post:
Old 01-11-2012, 10:12 AM   #4
jamestrd's Avatar
Trade: wood flooring
Rewards Points: 1,280
if there already isnt a date, request a walk through before bidding..these questions will then be answered..
do not run machines on a generator..doubt you will even find one capable of that load.
its a public job, the budges are big, but competitive..
factor accordingly..
HS/College gym much harder..nice to get your feet wet on elementary schools where things are not as crucial..good way to learn line painting.
James Hernandez
All Flortec Inc.
West Milford,NJ
www.flortechardwood.net
jamestrd is offline
Old 01-11-2012, 11:32 AM   #5
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,016
Should be a 220v nearby. Idealy a sparky could come in and add a pigtail from the box with a plug on it or a jct box with with a plug. He'll add a breaker or disconnect something not needed.
You can also visit the premises and talk to the maint guy and look around.
We Fix Houses is offline
Old 01-11-2012, 01:49 PM   #6
tom wentzwood's Avatar
Trade: Hardwood flooring
Rewards Points: 25
When doing a gym punch all 4 corners first before sanding a gym a booster box is always a good thing less strain on sander mortor, and SUB your lines/logo out to some one who has done this before . be careful on buffing maple floor under them lights finner grit better. if grit to rough swirly marks EEK!! best of luck. tom wentzwood Phoenix Arizona
tom wentzwood is offline
Old 01-11-2012, 02:16 PM   #7
PRO
BrandConst's Avatar
Rewards Points: 1,000
Go with Griz....ESPECIALLY take note of the moisture test...this is huge CYA!
BrandConst is offline
Old 01-11-2012, 08:59 PM   #8
Particulate Filter
Trade: Flooring
I decided to toss this one to a fellow competitor for some good will and a kickback if he lands the job.
2 part epoxy garage floor square foot price. Saturn9876 General Discussion 28 05-13-2011 02:54 PM
330 square foot apt. - 24 rooms shanekw1 General Discussion 6 10-28-2010 09:48 PM
Average price Square foot eandrews54 Construction 1 03-21-2010 09:33 PM
Pricing Per Square Foot LucyQ Business 6 05-08-2008 04:55 PM
New Construction, if per square foot, do you charge for garage? robertpaint Painting & Finish Work 2 05-01-2008 07:38 PM
