1000' Ceramic Tile
Old 02-05-2009, 01:01 PM   #1
Carpenter
woodbutchr's Avatar
1000' Ceramic Tile
I have about 1000 ft. of 16" x 16" Ceramic tile to lay inside a store. There is Berber carpet glued down to a painted concrete floor now. When the carpet is pulled up, what special prep do I need to do to make sure the thinset will adhere to the floor properly?
I was thinking that since the floor is painted that the thinset would be a problem but there is glue already on it now with the carpet?
Do I need to use a special adhesive for this application? Does the carpet glue have to come completely off the floor prior to installing the tile?
I don't know the condition of the floor right now since the carpet is still down but according to past experiences with this place, it should be in great shape.
I appreciate it guys. I play with wood most of the time but right now I just can't pass this job up. It's inside and it's WORK!
woodbutchr is offline
The Following User Says Thank You to woodbutchr For This Useful Post:
mtgdesigns (02-13-2009)
Old 02-05-2009, 01:14 PM   #2
detroitMi's Avatar
Trade: Tile,Marble & Granite
Re: 1000' Ceramic Tile
yeah
detroitMi is offline
Old 02-05-2009, 03:29 PM   #3
Pro Deck Builder
AutumnWood Inc.'s Avatar
Trade: Deck Builder
Originally Posted by detroitMi View Post
yeah
Informative post, you must also be trying to get to P&R section
AutumnWood Inc. is offline
Old 02-05-2009, 05:17 PM   #4
Mellison's Avatar
Trade: Home Improvement General Contractor
When in doubt always use Latapoxy 300 by Laticrete.
Expensive. But not nearly as expensive as a call back.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline
The Following User Says Thank You to Mellison For This Useful Post:
woodbutchr (02-05-2009)
Old 02-05-2009, 07:26 PM   #5
Remodeling GC
kevjob's Avatar
try to remove all the glue residue as much as possible to get a good bond to concrete, flat trowel backsides of tiles and use a medium bed for those heavy suckers.
kevjob is online now
Old 02-05-2009, 07:36 PM   #6
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Kneepads
Alieve
We Fix Houses is offline
Old 02-05-2009, 07:41 PM   #7
Professional Instigator
rbsremodeling's Avatar
Originally Posted by We Fix Houses View Post
Kneepads
Alieve
Vodka mixed with grape gatorade
rbsremodeling is offline
Old 02-05-2009, 08:03 PM   #8
On another note be sure to have an understanding of addl unknown prep for this job . Sounds like there may be remnants of glue that need to be addressed. Consider a dustless drum sander from the rental store with #40 - #60 grit belts. Vac and light mop. Run heat and fan prior to working.
The proper thinset is determined by the absorption rate of the tile and substrate. The slab is now not going to have much of an absorption rate. Porcelain and quarry tile have significantly less absorption rates than "ceramic tile". Thus you must use a modified / epoxy thinset. As Mellison said Latapoxy 300 may be a good choice. These types of products only have a limited pot life. You can spend 15 - 20 min / hr just scraping out and mixing in a bucket. Use a dw mixer and 1/2" drill. You'll need a helper.
I have called both Laticrete and Custom tech support on occasion. The guys I've talked to are very helpfull with hands on information and years of experience. Sometimes you have to leave a mesage on their vm but they will call you back.
If you dont already know about this site check it out. http://johnbridge.com/
Hope this helps
Addl - Get a clear understanding of your joint width 1/4 or 3/8 etc. if they don't know? I always set up a sample board (1/4 and 3/8) for approval even if I have to buy 20 tiles myself beforehand. If you measure a 3/8 width from another store it may be 1/4 because it may come out to look like 3/8. Layout 3/8 and it may look like 1/2 after it's all finished depending on the tile. Tiles can also be modular meaning your 16" will actually be 15 5/8.....you think a 3/8 joint will be the right one.....The joint may look too big after its in. Thats a mistake I made in the past.
Old 02-05-2009, 09:17 PM   #9
Tile Contractor
Bud Cline's Avatar
Amazing!!!
Bud Cline is offline
Old 02-05-2009, 09:31 PM   #10
Handle It!
MALCO.New.York's Avatar
Why are we beating up "The Butcher"?????
He is CERTAINLY "One of Us"!!!!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 02-05-2009, 10:07 PM   #11
72chevy4x4's Avatar
getting all of the glue up can be a bugger. Any remnants would be a real pain when trowling out the mortar. A tile scraper with a sharp blade should get most of it up.
72chevy4x4 is offline
Old 02-05-2009, 10:28 PM   #12
Carpenter
woodbutchr's Avatar
Appreciate it fellers, I was basically looking for the proper thinset to use. The contractor I'm doin' it for will have his grunts do the carpet removal & floor prep, just double checkin' on that part.
Like I said, I play with wood mostly. I've done several cookie cutter tile jobs like Bathrooms, Kitchens and Showers but never a larger commercial job like this.
Nuthin' ventured, nuthin' gained.
Old 02-05-2009, 11:11 PM   #13
Knowledge Factory
Floordude's Avatar
You will need to get it back down to bare concrete. that means the glue & paint must go.
http://www.AustinFloorguy.com
Floordude is offline
Old 02-06-2009, 12:38 AM   #14
Tile Contractor
Bud Cline's Avatar
FINALLY!
Old 02-10-2009, 04:14 AM   #15
powder coating mogul
deadjed's Avatar
Trade: media blasting/powder coating
Hehehehe!
deadjed is offline
Old 02-12-2009, 03:44 PM   #16
R&D Tile's Avatar
Trade: Tile installations
Yup, have fun.
R&D Tile is offline
Old 02-13-2009, 12:56 PM   #17
Ford Guy's Avatar
Trade: carpenter
try a floor maintainer. they cost about the same to rent as the drum sander but they work twice as well. They are like a huge random orbit sander.
Ford Guy is offline
Old 02-18-2009, 10:02 AM   #18
b2dap's Avatar
Trade: Masonry, Tile, concrete & landscaping sometimes
Check out this Tile Floor Stripper by EDCO (ts-8 tile shark). This would definitely do the trick!! I used a similar model to do a floor about 3 months ago, worked like a charm!
b2dap is offline
Old 02-18-2009, 03:58 PM   #19
p1grinder's Avatar
Trade: flooring
i've allways used a 7" grinder with concrete wheel, dust shroud and vac. it sounds like a lot of work grinding on ur knees but it's the best.
p1grinder is offline
Old 02-18-2009, 08:01 PM   #20
Knowledge Factory
Floordude's Avatar
I'd like to have one of those multi-head, planitary gear, concrete eating, monsters.
National Equipment has one, and Taylor tools has an attachment for a floor buffer, or use their Extreme Machine.
how many courses for ceramic tile shower walls? Bazooka Joe Ceramic & Stone Tile 19 02-14-2009 11:06 PM
Estimate On Ceramic Tile Buca1025 Ceramic & Stone Tile 30 02-03-2009 10:56 AM
Ceramic Tile Bumps Unit 138 Ceramic & Stone Tile 7 12-28-2008 05:55 PM
Laying new ceramic tile on wall faromic80 Ceramic & Stone Tile 4 09-17-2008 08:01 AM
flooded ceramic tile floor on concrete bmorrisey Ceramic & Stone Tile 2 12-06-2007 09:35 PM
