Typically, when you buy a home you live there for many years. It could be ten years or even 40 years depending on where you're at and what happens. As you live in your home and spend a lot of time there, you can start to get bored with the décor or style you currently have. What you like now will change and you may be considering installing a new look altogether.
One thing you can do to make a new look in your family room, master bedroom, or any room in your home is to install a stone accent wall. Whether you go with a stone fireplace veneer look or you want a full wall in your kitchen area, these stone accent wall installation tips will be helpful in understanding the process and what you need to do to get the look you desire.
Decisions, Decisions
The first step you need to take is deciding what type of stone you want to install. There are all sorts of accent stones you can choose from depending on the look you're after. You want whatever stone type you choose to be sure to complement the rest of the room. There are light types of stone that offer a sandy color that goes well with pretty much any décor. You can also collect your own rocks and stones to add to the wall. You will truly have a unique story of where they came from offering up a unique centerpiece.
Be Sure to Measure
Another stone accent wall installation tip to keep in mind is to measure the wall you want to create the piece. You'll need a tape measure to get the height and length of the wall, then square that for the correct footage of the stones you'll need. You do not want to short yourself or get too much and have to cut again. You'll want to make sure and measure it twice to double check you have the right amount.
Preparation is Necessary
Working with this type of material is going to be dusty and messy. It is best that you take everything out of the room that you possibly can. Remove any photos or pictures on the walls, take out any furniture that can be moved, and cover anything that can't leave the room while you work. It is also wise to make sure and put down a floor covering to prevent any stains from the mortar or issues with dust and debris on your flooring.
Apply Cement Board
Once everything is prepared, then you can start to cut the cement board or whatever backing you're using. Take your wall measurements, cut the board to the precise size and then attach it to your wall. This is the base for your stone veneer fireplace or other accent wall décor. This is critical to making sure your stones stay in place.
Final Steps
Once your cement board is in place, you'll use a high strength grout to lay down and start stacking your stones. You want to layer them in rows of whatever pattern you choose. Make sure to attach the rocks in a single layer at a time to avoid any issues. Once you've laid them down, your final stone accent wall installation tips are to grout between the stones. While it isn't necessary, it will help to make sure everything looks precise and neat.
Be Sure to Measure
Apply Cement Board
Final Steps
